Brief Description: Drilled hole for wing tie down ring.
When I placed the leading edge assembly into position and continued the bisecting lines from the main skins up to the pre-punched hole for the tie down I ring I was happy to see that it lined up perfectly. I drilled it out to 15/32" with a Uni-bit and did not need to use a file to 'move the hole'.
