Brief Description: Conduit holes, engraving and bump removal.
I drilled the holes in the right hand main ribs to accommodate the wiring conduit, plus the small hole which I may use in the future for a nylon tie strap securing an additional conduit running down the second lightening hole from the leading edge. I then engraved the rib part number and position ID into all the ribs. Lastly I began removing the bump on most of the nose ribs I have read can lead to a bump in the leading edge skins. I just used my snips and a small round file to open up the space a bit. Picture of completed ribs will follow in next log entry.
