Brief Description: Pitot tube installation - Part 1.
Using the template I marked then cut out the hole in the left wing bottom outboard skin to accommodate the Pitot tube support from Safe Air 1. I am using the heated pitot / A of A probe from Dynon which fits nicely into the Safe Air support. I used a bit of aluminum tape to improve the fit of the probe to support. Next up is to drill and tap the attachment holes in the probe.
