Brief Description: Attached Rudder to Vertical Stabilizer.
I jumped ahead just a bit. I needed to see the Rudder and VS as one. I measured and set the three rod end bearings as per the plans and installed the Rudder. The middle rod end had to be lengthened by 1.5 turns but other wise it was a non issue to get the hinge bolts in place. The rudder swings perfectly with no binding whatsoever.
Next up is continue working on the Right hand Elevator.
