Brief Description: Torqued the HS-411PP center bearing bolts.
I finally received my CDI torque wrench from Avery. It has a range of 20-150 Inch/Pounds. The AN3-5A bolts call for torque from between20-25 Inch/Pounds and I added 5 Inch/Pounds for the nylon insert in the nut for a total torque value of 30.
I used orange Torque Seal and marked the bolts/nuts from the underside. I'm not sure if I will ever be able to inspect these bolts once the aircraft is complete but I'm hoping that I will.
