Jeff Mitchell's RV8 project
Date:  11-10-2006
Number of Hours:  5.00
Manual Reference:  Training drawing
Brief Description:  More work on the Aileron section kit
Continued work on the Aileron skeleton. Riveted the reinforcement plates to the main spar and side ribs. Drilled the trailing edge wedge using an angle gauge set to 84 degrees. Clamped the whole assembly to the work suface to facilitate drilling at an angle. Finished the day with riveting the bottom skin to the main spar.
Riveted reinforcement plate
Drilled trailing edge wedge
Bottom skin riveted to main spar
