Brief Description: Applied epoxy floor coatings to garage.
In preparation to moving the project into the garage in the next couple of months I took the time to refinish the floor. I applied 2 coats of epoxy grey followed by 2 coats of epoxy clear. I used the Rust-Oleum system with good results. If you want that smooth 'wet' look don't use the 'no slip' silica sand additive but be aware it will be very slippery with water on it.
