Brief Description: Started fuselage final assembly.
I finally began final assembly of the fuselage. I started with bolting and riveting the F-843 lower longerons to the forward assembly. Then I riveted on the lower gussets to the forward fuselage bulkheads and then joined the center section to the forward section at the mid cabin braces. I also installed some platenuts to the side bulkheads and armrests.
