Brief Description: Adding Tailcone to fwd fuselage section.
I used the solder iron trick to remove the vinyl along the rivet lines on the inside of the aft side skins. I did this to mask of the areas outside of the rivet lines which I don't plan on priming. I also removed the vinyl completely on both sides of the aft bottom skin, as I plan on priming the entire inside surface of this one.
