Brief Description: Final drilled arm rests and mid skin bulkheads.
I final drilled the F-808 bulkhead to the aft seat ribs and did the same for the arm rests and mid skin bulkheads. I also tweaked the auxiliary longerons a bit where they will atach to the lower firewall mounts. Then I continued work on the manual aileron trim system.
