I used a couple of straps to position the right hand aileron in position so I could install the mounting hardware. I used the jig to set the neutral position and installed the pushrods. I used a Delrin rod with a 0.55" O.D. cut to length and drilled a hole for the aluminium spacer to provide a stop for downward travel limit as suggested on several builder logs. It works great.
