I used my new pneumatic rivet puller to set the remaining blind rivets in both ailerons. The instructions call for installing the A-406 / /A-407 brackets after installing the end ribs, but they would cause interference with setting the end rib rivets on the bottom skins so I left the installation of these until the end. Both ailerons came out perfectly straight. Next up is to install the hinge brackets.
