It took 15 hours to complete the inventory process of the fuselage kit. I labelled each shelf with a coded number and noted the location of each part next to the part number listed in the inventory sheet so I will be able to quickly locate the many parts I will use to build the fuselage. Everything was there (I got a couple extra bolts and washers). The only problem was a long scratch across the instrument panel. I will call Van's about it soon.
