Brief Description: Right tank end ribs and sealed shop heads.
I mixed up a fresh 6 oz tube of PRC and applied sealant to the shop heads of the rivets of the inner ribs of the right hand fuel tank. I used a syringe to apply sealant to the rivets at the leading edge because my Semkit gun is a bit too long to get to those ones. Then I sealed the inboard and outboard ribs and clecoed them in place and sealed the shop heads of the outboard rib after setting the rivets with my pneumatic squeezer. I finished up with sealing and riveting T-405/T-510 in place at the leading edge of the inboard rib.
