Brief Description: Left tank fuel vent line and fittings.
I spent some time carefully bending the fuel vent line then flared the end using my new flaring tool from ATS. I lightly tightened things in place to check for fit. I still have to bend the end of the fuel vent line up so it is positioned at the highest point of the tank and will set the B-Nuts down to the proper torques once I rivet the most inboard rib in place.
