Brief Description: Tank anti hang up and float sender wire.
I fabricated the anti-hang up that goes between the stiffener and the second rib. I decided not to use this one because I think I can do better if I try again. I will cut some more .040 at work then repeat the process. I did manage to bend the float sender wire to shape. Don't forget there is a right hand and a left hand sender unit and there is a 3/4" bend at the end of the wire that goes through the sender unit. Look closely at the supplemental plans sheet that comes with the senders.
