Jeff Mitchell's RV8 project
RV-8
Trim Tab construction (4).
I match drilled the control horn and marked the location of the hinge then drilled it to the tab skin and trim tab spar. I used two 1/8" drill bits to line up the two control horns instead of a 'clevis' pin as the manual suggests.
Match drilled the trim tab control horn
Marked and drilled the hinge
Finished edges, deburred holes
RV-8 Home
4065
Ailerons
25
84
324
Flaps
Fuel Tanks
54
190
1889
Misc Pics
Pics of me building
Training Kits
557
Workshop Setup
