Brief Description: Fuel system check and iPad mount.
Paul was over to assist with checking the fuel line fittings. We disconnected the fuel line to the engine and placed it in a container then added 5 gallons of 100LL in each tank. I ran the boost pump to flush the lines and filter and check for leaks. No problems so we capped the line that was fed to the container and turned on the pump again to check for leaks in the plumbing under the higher pressure. No problem. Then I fabricated a doubler to go under the Ram Mount I ordered for my iPad Mini and installed that.
