Paul was over to lend a hand installing the wings. I used 7/16" hardware bolts with the threads cut off as temporary pins while Paul jiggled the wings up and down allowing them to slip in easily. I then replaced them with the close tolerance bolts and finished up with completing the connections for fuel supply and tank venting. Tomorrow I will install the washers and nuts, electrical connections and re-install the flaps. It all went together with minimal grief. Thanks Paul!
