Brief Description: Cowl Installation continued - Part 8.
The PRC set up on the cowl hinges so I took the morning to countersink then set the rivets to complete the hinge installations. The left side came out very well but the right side just near the front has a bit wider a gap than I would like so I will do some work to narrow it up a bit with some resin/Flox next time I mix up a batch. Regardless, I can finally say the project is officially out of the 'porcupine stage'.
