Brief Description: Cowl Installation continued - Part 6.
I spent the day working on the cowl. I installed the four SkyBolt C-Lok fasteners at the bottom of the cowl, installed plate nuts at the inlet joints, did some more fine tuning sanding at the edges and finally enlarged the air outlet by cutting a line forward of where the stock cowl ends as recommended by someone who knows this helps with cooling.
