Brief Description: Cowl Installation continued - Part 4.
Another session with Larry made good progress on the cowl. We finished trimming the upper and lower cowl and used a template with the proper hole spacing to drill rivet holes in the hinges. Then it was easy to drill through the template into the cowl and into the already drilled holes in the hinges.
