I drilled out the center hole of three firewall penetration kits that I will use to secure the cables for throttle, mixture and propeller pitch. The kits are from Doubletee Products (www.doubleteeproducts.com) available from Aircraft Spruce. I step drilled the final hole diameter to 21/64" one drill size up at a time.
