I can't seem to leave well enough alone. I decided to apply a technique in the instructions to fill a void between the skirt and the fuselage I had on the left hand side 3/4 of the way back. I taped on some wax paper then mixed up some Micro / Epoxy and filled the small void where the skirt didn't quite meet up with the fuse. Tomorrow I will sand the top layer of the skirt at this area to maintain the same thickness as the rest of the skirt. I finished up with a small touch up around the aft end ramp over the slide rail.
