I wet out a couple pieces of BID and applied them to the underside of the aft canopy notch to provide a bed for some Epoxy mixed with Flox then clamped a waxed piece of aluminum scrap to mold the proper shape in place. This should fix the mistake I made last session when I cut the notch too high. Then I applied some Epoxy Flox to fair the aft joint smooth and added a fillet to each side of my canopy pull ring thingy.
