I set the blind rivets to finish off the installation of the skirt to canopy frame. Then I mixed up some Epoxy Resin and applied a couple layers of BID to the bottom aft joint plate for added strength. I finished by mixing in some Flox to the resin cup and applied it to the top forward portion of the aft joint (Image 2 is taken with canopy inverted).
