Brief Description: Utility plugs and VP-50 powered up.
I installed the wiring to the two utility plug receptacles on the left hand side of the cockpit and installed the ground and power connections to the VP-50. I only had two circuits wired to it, the intercom and the two utility plugs but everything worked as advertised. The VP-50 was easy to program and it was pretty cool to see it working!
