Brief Description: Wired flap relay board - Part 1.
I carefully followed the wiring diagram provided with my Airplane Extras flap relay board and hooked it up to my Infinity stick grip and a 12 Volt power source. The system worked perfectly and best of all there was no smoke and or flames! Now I have to figure out how to incorporate the airspeed switch which will prevent inadvertent flap deployment above Vfe. This was just a proof of concept run, I still have to wire it properly to the aux bus and aircraft common ground bus.
