Brief Description: Infinity grip on new bent stick - Part 2.
I finished mounting the Infinity grip onto my new bent control stick. This required some internal trimming of the grip to accommodate the bend in the stick. I primed the end and fed all the wires through. I used a multimeter to check for circuit continuity in all the switches then installed it into the cockpit. I like the position of the grip much better than the stock vertical control stick.
