Brief Description: Improving fuselage rotisserie - Part 1.
I installed the front frame of my rotisserie then set up a water level to determine the fuselages axis of rotation. The water level shows the point of rotation at the aft most point of the fuselage is about 1 inch below the center of the hole for the tail wheel stinger. I will modify an adjustable stand to support the aft end of the fuselage.
