Brief Description: Wing to fuselage fairings - Part 1.
I joggled and trimmed the aft wing fairings. Then shaped the leading edge curve of the front fairings, clecoed them in place and match drilled the #30 holes around the inboard tank edge. I finished up the day by marking the fairings at 3/16" from the fuselage side. I will trim this away tomorrow which will accommodate the rubber gap seal at final wing installation.
