Brief Description: Static system - Part 3 and ADAHRS shelf.
I figured before I rivet on the F-825 Aft upper skin I should fabricate a mounting shelf for the Dynon SkyView ADAHRS I plan on using and install a T-Fitting for the static source input. I used the dimensions found in the Dynon SkyView installation manual and made a template out of some scrap aluminum. Then I built a simple shelf from light aluminum angle. I installed the support shelf between F-809B and F-810A bulkheads. This location meets the Dynon requirements. I plan on only one ADAHRS but just in case I drilled holes to accommodate two side by side units.
