I'm using the Pitot/Static system from SafeAir 1. I marked and drilled three #40 holes spaced at 120°. I applied ProSeal and used a piece of wood to hold them in place. Once the sealant has cured I will back drill the static ports into the fuselage skins and countersink for flush rivets.
