Johns Web Site
Date:  6-26-2016
Number of Hours:  6.00
Brief Description:  Fitting of instrument pod
I mounted the pod directly to the pod mounts. It was easier and provided good support along with the bolts in the instrument panel. In the second pic, I used a jig that is used to hold pipe so that you can drill a straight and even hole (worked good here).
Bolted to instrument panel
Drilled pod supports
Finished mounting of pod
