Worked on getting final paint job on big parts (bottom, firewall, main sides). I was not happy with some of the panels that I had primed earlier because of scratches I found and ending up wet sandiong them again. I will finish them up tomorrow (Sat). Made the mistake of not lowering the hanger door down to cut out overspray (slight wind came out of nowhere!). Ended up getting some on the tail boom which I promptly wiped down. So far I am pleased with the color. Hopefully I will have all the painting done either by the middle of Aug or by the beginning of Sept depending on the weather.
