Brief Description: Installation of Flight Controls
Installed flight controls but ran into a slight problem. The bolt that was used to widen the control horns got in the way of the control rod ends. So i made a wedge out of wood to fit above the bolt hole. I would use the bolt to spread the horn, insert the wedge to hold the spacing, then insert the control rod end and finally punch out the wedge once the control rod was bolted in.
