Brief Description: Instrument pod construction (cont'd)
Started fitting the instruments in the panel only to find out (pic 1) I misaligned the holes on the transponder and was not happy with having to add washers. Also found out that the EFIS cutout was too wide (1/8"). I redid the entire panel again but took real careful measurements. No 3 pic is the final out come. Everything fit perfect. Now I have to prep the panel for painting.
