Brief Description: Installation of Eyeball penetrations and others
I liked the idea of builder William Johnson using Eyewall Firewall Penetrators for the wiring. It makes wiring easier to go through bulkheads and looks neater. I used a 1" hole saw to make the holes. I also went ahead and and temporarily mounted the cabin heat box. In pic #3 you can see where I screwed up in placing the hole too close to the frame. The eyeball will not fit - so I will probably get a 1" rubber gasket to cover the mistake.
