Johns Web Site
Date:  7-17-2016
Brief Description:  Stabilizer wing construction
Started work on the stabilizer figuring this would be a somewhat easy task. Cut the sheet metal to right deminsions and using a piece of galvinized pipe as guide I bent the sheet metal over using heat and clamping the metal into the wing. Later you will see that this did not work out the way I intended!
Forming of stabilizer
Make shift aids
Make shift aids
