Brief Description: Pilot, Co-pilot and Middle Wells
After re-making each of the pilot, co-pilot and middle wells, I had to figure a way to bend the ends over the seat frames. I made a small rig consisting of 2x4's with a steel rod that was the same diameter as that of the seat frame. Then using a hammer and a plummers torch, I heated a small portion of the aluminum and used the hammer to form a rolled edge.
