Johns Web Site
Date:  2-28-2015
Brief Description:  Accelerator Rod Bolt End Broke
Ran into a slight problem. While sanding down the ends of the accelerator rod, I went through part of the weld on one end that held the threaded bushing for the bolt. Went to tightend the bolt down and the bushing popped out. Called the good folks at Safari and they fixed it real quick. They ended up welding the bushing to the inside of the tube to keep this from happening again. Had it back in a 1 1/2 weeks fixed and painted!
Sanding to fit
Sanding to fit
OOPS!!
OOPS!!
