Brief Description: Brief install of position lights
I drilled the holes for the left and right position lights. However, I should have drilled the holes prior to painting! I used a step-up drill bit to make the hole and chipped a little bit of paint around the hole. I will fix that before I had the clear coat on. All the lights are LED.
