Johns Web Site
Date:  9-17-2014
Number of Hours:  6.00
Brief Description:  Temp Install of Fuselage Panels
After fitting most of the flight controls, I started fitting the fuselage together to be riveted. At first I used a thin material (used in bathroom showers - vinyl covering) to cover the areas of the legs that could be damaged while installing the panels. That did not workto well. Instead I used painter's tape and so far that has worked better.
Unprotected  Leg
Unprotected Leg
Protected Leg
Protected Leg
Use of Painters Tape
