Jim's Web Site
Date:  7-17-2004
Number of Hours:  6.00
Brief Description:  Finished Horizonal Stabilizer
No pictures of this work day. The camera went south. Spent the day riveting the skins on the horizonal stabilizer. The job is completed and is ready to hang on the wall except for one repair. The bilind rivet in the right 608 rib to rear spar attachment is not holding the flange down to the rear spar. Talked to Vans and they agreed that a #6 screw with a nut would do fine to replace the rivet and pull the flange tight. They also suggested drilling another hole in the center of the flange and add another blind rivet. I may do that if the screw does not pull the flange down tight.
