No pictures. Messed with the VS 705 nose rib to try to close the gaps between the rib flanges and the skin, particularly at the nose. After much fiddling I have come to the conclusion that the time spent making sure the rib flange was at a right angle to the rib web was wasted effort. The vertical stabilizer tapers from root to tip, so the rib flanges will not be normal to the web.
