Deburred inside right side HS, top and bottom. Started using the 1" scotchbrite wheel in the die grinder to knock the burrs off the holes. I think it works better than anything else I've tried. Also deburred the #41 holes in the right side main and nose HS ribs ( ribs 6 to 10).
