Brief Description: Fit the corner ribs to the bottom skin
Fit the corner ribs to the skin. The drawing shows a detail of the corner ribs. The ribs had a nose with a wobble that looked like it should fit within the bulkhead. The drawing didn't show that wobble. It looked like the end of the rib was cut off and not directly attached to the bulkhead. Just the straps attach the ribs to the bulkhead. After much consternation I took the plunge and cut the rib. In the end, both ends of the rib get cut. First cut the front to get the rib angle to match the shape of the skin, and then cut the rear to allow the next bulkhead to slip underneath the baggage ribs and the fabricated rear strap. I think it came out very nice. I just took my time and thought it out very carefully. Some things are just natural and go together as logic dictates they should, others are not as clear. This was one of those times when you just can't study the plans enough.
