Brief Description: Rivet side skins to bottom skin
Rivet side skins to bottom panel. This was fairly difficult to do. The rivet is put into the hole and held from the inside so it won't fall out. Then the rivet gun is held firmly against the rivet, lined up for the correct angle and position over the rivet. Hold that, don't move. Grab the bucking bar and place onto the rivet. Squeeze the trigger and hold everything in place. If it is all done correctly you will have a rivet correctly smushed. One down, too many to count to go. I guessed at the time spent because of all the bend and stretch required I did a few rivets and stopped, came back later and did several more. As the row of rivets continues toward the front the reach required becomes greater untill you get to the very front section. The bucking bar was barely in my fingertips as I bucked the remaining rivets. Fourtunately I had to drill only a couple of rivets that had not set correctly.
