Spent some time getting the wing box with all of the fiberglass parts carefully packed inside moved out of the way. The wing box and the fuselage box are the same lenght. I must have checked and measured all of the boxes from the website because I had exactly the correct distance beween the wall and the file cabinet in the basement. The fuselage box is about 6 inches wider than the wing box.
Opened the crate and began to inventory all of the parts. This time I put the small parts into other boxes and marked a box number on the packing list. Later I was able to make a list of what parts were in each box. Hopefully that will keep the rooting through the boxes to a minimum. Boy, sure is a lot of pieces.
