Brief Description: Install ailerons and control rods
Re-engineered the pitot mast which then would clear the aireron push tube. Installed the ailerons. Thats when I discovered I was using the wrong location at the bellcrank.With the bellcranks positioned correctly the tubes moved smoothly. Also with the tubes in the correct position the pitot line would have had lots of clearance. Oh well, I like the set up better now than before so it was not all wasted effort.
